New Products in Essential Analog Portfolio by Maxim Shatter Industry Benchmarks in Power, Solution Size and Accuracy
Maxim MAX6078A MAX16155 MAX16160
MAX6078A, MAX16155 and MAX16160 deliver precision measurement and reliable protection for consumer, communications, industrial and medical applications
Designers can further reduce power consumption and solution size, while improving measurement accuracy, with three new industry-leading analog products from Maxim Integrated Products. The MAX6078A voltage reference IC, the MAX16155 nanoPower supervisor and the MAX16160 voltage monitor and reset IC achieve best-in-class performance for cloud infrastructure, IoT, intelligence-at-the-edge, on-device AI, as well as smart and emerging applications in consumer, communications, industrial and medical markets.
Maxim - MAX6078A, MAX16155, MAX16160
As designers develop new and next-generation systems for greater performance, smaller size and innovative capabilities, they demand reliable analog solutions to provide essential performance functions such as precision measurement and reliable protection. Maxim leverages world-class circuit design expertise and unique advanced process technology to provide high-quality building block ICs that support system advances in multiple applications.
Maxim has added three new solutions to its Essential Analog portfolio of high-performance, single-function analog ICs which provide efficient power, precision measurement, rugged connectivity and reliable protection.
Maxim's New Solutions in Essential Analog Portfolio:
  • MAX6078A:
    Precision Voltage Reference Delivers Industrial Level Accuracy on a Tight Battery Power Budget.
    The MAX6078A features ±0.04 percent initial accuracy, 20 percent more accurate than similar competitive devices. At 15 µA quiescent current, the MAX6078A opens the potential for precision measurements on battery-powered and energy-harvesting systems. It operates at 6.6x less current than the closest competitive parts and, at 1.458 mm × 1.288 mm, is 58 percent smaller than competing solutions.
  • MAX16155:
    Industry's Lowest Power nanoPower Supervisor.
    The MAX16155 consumes just 400 nA typical, or only 4 percent of the supply current that competitive solutions require, providing reliable system protection for virtually no power. It ensures portable, low-power devices operate safely in the event of a power failure or code error by monitoring a system rail for undervoltage fault and keeping the system in reset when it senses the fault along with a watchdog timer. The IC comes in a tiny, 6-pin SOT23 package.
  • MAX16160:
    New 4-Channel Voltage Monitor and Reset IC Without VCC Rail Power-Up Requirement.
    The MAX16160 is the only 4-channel voltage monitor and reset IC that uniquely asserts reset low without requiring VCC rail if any of the rails is above 1 V. It features the industry's most reliable start-up and continuous operation of multi-supply systems by asserting output low. This "no-power power-up" eliminates unknown system states and significantly reduces the burden on design engineers to accurately sequence their power rail startup. With a voltage monitoring accuracy of ±1 percent for all inputs, it is up to 50 percent more accurate than competitive offerings (commonly ±1.50 percent for all inputs). Its 6-bump WLP (1.408 mm × 0.848 mm) is 85 percent smaller than the closest competitor.
Availability and Pricing
  • MAX6078A is available at Maxim's website for $1.21 (1,000-up, FOB USA); MAX6078EVKIT# evaluation kit is available for $39.
  • MAX16155 is available at Maxim's website for $1.25 (1,000-up, FOB USA).
  • MAX16160 is available at Maxim's website for $1.87 (1,000-up, FOB USA).
Evaluation Kit for the MAX6078A
Evaluation Kit for the MAX6078A.
