NJR to Provide Samples of High Precision Adjustable Shunt Regulator NJM17431
New Japan Radio NJM17431
New Japan Radio (NJR) launches a high precision adjustable shunt regulator NJM17431, and has begun providing sample products
NJR provides samples of a new adjustable shunt regulator NJM17431 with high precision and wide stable operation region that has been designed by latest process and analog circuit technology for many years.
NJR - NJM17431
Because the NJM17431 has 0.8% accurate voltage reference and wide stable operation region for large capacitive load, it can be used for a very wide range of applications. And it can replace Zener diode with the NJM17431.
Since the stable operation region is wide, it will help engineers reduce the design man-hours and the burden of replacement evaluation.
The NJM17431 operates stable in the range of 0.01 μF to 100 μF with the actual usage cathode current region.
Characteristics
  • Reference Voltage Tolerance: 2.5 V±0.8%
  • Adjustable Output Voltage: VREF to 36 V
  • Wide Stable Operation Region
  • Low Temperature Coefficient of Voltage Reference
  • The output voltage can be set with two external resistors
  • Bipolar Technology
  • Package: SOT-23-5
Application
  • Industrial Equipment
  • Home Appliances
  • Precision Power Supply
  • Zener Diode Replacement
  • Production Schedule
Enter mass-production in the second quarter of 2020
