Achieve 20-25 years of battery lifetime, and the high performance of the 32-bit ARM Cortex-M3 with Energy Micro's new EFM32 microcontroller
Energy Micro EFM32
Energy Micro is proud to introduce the EFM32 microcontroller family, which has an energy consumption that is many times lower than any other microcontroller family today, whether you benchmark with leading 8, 16 or 32 bit microcontrollers. With the EFM32 you can easily obtain battery lifetime in the 20-25 years range while at the same providing the high performance of the 32-bit ARM Cortex-M3.
Features:
  • 32-bit ARM Cortex-M3 running up to 32 MHz
    • 1.25 DMIPS/MHz
    • Superior Math Capability
  • Single 1.8 to 3.8 volt power supply
  • –40° to 85°C operation range
  • Up to 32 KB Flash and 4 KB RAM memory
  • Up to 56 GPIO with 20 mA drive strength
  • 16 External Interrupts
  • Direct memory access Controller (DMA)
  • Peripheral Reflex System for autonomous operation
  • Hardware AES with 128/256-bit encryption/decryption
  • Integrated high and low frequency oscillators
  • USARTs with UART and SPI modes up 16 Mbit/s
  • Low Energy UART with 100 nA receive mode
  • 16-bit Timer/Counters with Compare/Capture
  • Low Energy TIMER with optional pulse outputs
  • Flexible 24-bit Real Time Counter
  • Pulse Counter
  • Configurable LCD Controller driving up to 4×24 segments
  • 12-bit ADC, 1 Msamples/s, 8 channels
  • 12-bit DAC, 500 ksamples/s, 2 channels
  • Analog Comparators with 8 input mux and capacitive sensing capability
  • On-chip Power-on Reset and Brown-out Detector
EFM32TG Lineup
Part number
Family
Core Variant
Freq.
Flash/ROM
Package
EFM32TG200F32
 EFM32TG
 ARM Cortex-M3
 32MHz
 32768
 QFN 32
EFM32TG200F16
 32MHz
 16384
 QFN 32
EFM32TG200F8
 32MHz
 8192
 QFN 32
EFM32TG840F32
 32MHz
 32768
 QFN 64
EFM32TG840F16
 32MHz
 16384
 QFN 64
embeddeddeveloper.com
