LUCY-H200 3.5G modem module
u-blox LUCY-H200
The LUCY-H200 3.5G modem module provides full tri-band HSDPA and quad-band GSM/GPRS data and voice communication in a compact form factor. Featuring HSDPA data-rates of up to 7.2 Mb/s, GPRS/EDGE class 12 data transmission, voice, SMS and Fax capabilities, LUCY covers a wide range of data and voice applications. A rich set of Internet protocols is supported. LUCY comes in a compact form-factor and has very low power consumption.
u-blox - LUCY-H200
The LUCY-H200 3.5G module is a fully qualified and certified solution, reducing cost and enabling short time-to-market. LUCY is ideally suited for M2M, mobile broadband and automotive applications such as: Automatic Meter Reading (AMR), Remote Monitoring Automation and Control (RMAC), surveillance and security, mobile Internet and VoIP routers, road pricing, asset tracking, fleet management, anti theft systems and Point of Sales (PoS) terminals.
For telematics applications, LUCY offers fully integrated access to u-blox GPS receivers via the module. Wireless and GPS are controlled through a single serial port from any host processor, and A-GPS (AssistNow Online and Offline) functionality is integrated in the wireless module.
Certifications
The LUCY-H200 UMTS/HSDPA module is undergoing certification by the following standardization organizations: FCC, IC, PTCRB, and R&TTE. LUCY has also demonstrated compliance with the Global Certification Forum (GCF) requirements. Certificates will be published as they are received.
To order samples of LUCY, please contact the u-blox sales representative nearest you.
Features:
  • UMTS/HSDPA tri-band
  • GSM/GPRS/EDGE quad-band
  • 2 UARTs
  • DDC (I2C) for u-blox GPS
  • 5 General purpose I/Os
  • ADC
  • SPI
  • USB
  • SIM
  • Analog Audio
  • Digital Audio
  • Network activity indication via dedicated pin
  • Antenna Supervisor
  • Jamming Detection
  • Firewall
  • TCP/IP, UDP/IP (multiple sockets)
  • Internet: FTP, HTTP, SMTP, HTTPS, FTPS
  • SSL (HTTPS, FTPS)
  • GPS via GSM Modem
  • Simple integration with u-blox GPS modules and Assisted-GPS service
  • Access to u-blox GPS modules via LUCY
  • Embedded AssistNow Client
  • Firmware update over UART
  • Firmware update over-the-air
Highlights:
  • UMTS HSDPA tri-band 2100 MHz (Band I), 1900 MHz (Band II), 850 MHz (Band V), 7.2 Mb/s downlink
  • GSM/GPRS/EDGE quad-band, class 12
  • Embedded TCP/IP and UDP/IP stack
  • SSL client (HTTPS, FTPS)
  • Lowest idle mode current: < 2 mA
  • Simple integration of u-blox GPS and A-GPS
  • Operating temperature range: –25 °C to +70 °C
  • Board to board 60-pin connector
  • USB and serial ports
  • Small form factor: only 45.1 × 37.5 × 4.42 mm
  • Evaluation software m-center available
  • Evaluation kit EVK-H26H available in June 2010
www.u-blox.com
