High-Side, Current-Sense Amplifiers with 12-Bit ADC and Op Amp/Comparator
Maxim MAX9611 MAX9612
Maxim introduced the MAX9611/MAX9612, the latest additions to its industry-leading portfolio of high-side, current-sense amplifiers. Designed for industrial, consumer, and automotive applications that require digitized current-sense data, the MAX9611/MAX9612 integrate a 12-bit ADC and a gain block that can be configured as either an op amp or a comparator. This integration provides the key components for easy implementation of fault monitoring and closed-loop control applications, such as inrush-current limiting and gain control.
The high-side, current-sense amplifiers operate over a wide 0V to 60V input common-mode voltage range. The programmable full-scale voltage (440mV, 110mV, and 55mV) of these amplifiers offers wide dynamic range, accurate current measurement, and application flexibility in choosing sense resistor values. A choice of either an internal op amp or a comparator is provided to the user. The internal amplifier can be used to limit the inrush current or to create a current source in a closed-loop system. The comparator can be used to monitor fault events for fast response.
Maxim - MAX9611, MAX9612
An I2C controlled 12-bit, 500sps analog-to-digital converter (ADC) can be used to read the voltage across the sense resistor (VSENSE), the input common-mode voltage (VRSCM), op-amp/comparator output (VOUT), op-amp/comparator reference voltage (VSET), and internal die temperature. The I2C bus is compatible with 1.8V and 3.3V logic, allowing modern microcontrollers to interface to it.
The MAX9611 features a noninverting input-to-output configuration while the MAX9612 features an inverting input-to-output configuration.
The MAX9611/MAX9612 operate with a 2.7V to 5.5V supply voltage range, are fully specified over the –40°C to +125°C automotive temperature range, and are available in a 3mm x 5mm, 10-pin µMAX® package.
An evaluation kit is available: MAX9611EVKIT.
Key Features
  • 0V to +60V Input Common-Mode Voltage Range
  • 2.7V to 5.5V Power-Supply Range, Compatible with 1.8V and 3.3V Logic
  • 5µA Software Shutdown Current
  • Integrated 12-Bit ADC
  • 13µV Current-Sense ADC Resolution
  • 500µV (max) Current-Sense ADC Input Offset Voltage
  • 0.5% (max) Current-Sense ADC Gain Error
  • I²C Bus with 16 Addresses
  • Small, 3mm x 5mm 10-Pin µMAX Package
  • –40°C to +125°C Operating Temperature Range
Applications/Uses
  • Base-Station Feeder Cable Bias-T
  • Base-Station PA Control
  • Battery-Operated Equipment
  • Hybrid Automotive Power Supplies
  • Server Backplanes
  • Telecom Cards
Typical Application Circuit
MAX9611/MAX9612 - Typical Application Circuit
Key Specifications
Part
Number
CMVR
(V)
VCC
(V)
ICC
(µA)
VSENSE_FS
(mV)
VOS@25°C
(µV)
Gain
Accuracy
@25°C
BW
(kHz)
Oper.
Temp.
(°C)
Package/
Pins
min
max
min
max
recomm.
max
@–3dB
MAX9611
0
60
2.7
1600
No
300
Adj.
4000
1
–40 to +125
µMAX/10
MAX9612
