Electronic Design
By adding a resistive divider and dc voltage to a standard dc-dc regulator, you can easily develop dc rails below 1 V, all the way down to just a few hundred millivolts.
You can generate a tiny dc supply voltage of a just a few hundred millivolts using an additional positive voltage connected to the feedback resistor of a dc-dc converter. The need for such a low-voltage rail is increasingly commonplace as supply voltages for electronic components have been decreasing steadily over the last few years. This is largely due to the decreasing size of the geometrical structures in digital circuits such as microcontrollers, CPUs, DSPs, and others. Applications in the measurement field also require low supply voltages.
For many years, linear and switching regulators had a feedback voltage of approximately 1.2 V. This voltage was generated with a bandgap circuit in a dc-dc converter IC, which determined the lowest voltage that could be set with an external resistive divider. Now, most modern voltage-regulator ICs can generate output voltages of 0.8 V, 0.6 V, or even 0.5 V.
The internal voltage reference is designed in such a way that lower voltages are possible using a switching regulator such as the LTC3822, which generates a feedback voltage of 0.6 V with a 0.6-V voltage reference (Fig. 1). However, if a supply voltage of less than 0.6 V is required, that circuit can’t be used without further adjustments.
Figure 1. | An LTC3822 dc-dc converter can be used to generate low output voltages down to 0.6 V. |
With a trick, however, you can make a switching or linear regulator also generate lower voltages than the feedback voltage. This can be achieved by using circuits like the one shown in Figure 2. It requires an additional positive supply voltage to which the resistive divider is connected for adjustment of the output voltage.
Figure 2. | The circuit is modified to generate output voltages of less than 0.6 V. |
This voltage can come from a low-dropout (LDO) regulator or a voltage reference. The resistive divider thus forms a voltage divider in which the current flow IFB flows in a direction opposite to the normal case of Figure 1. Instead, the current flows from the external reference voltage through the resistive divider to the output voltage. The following equation shows the relationship between the feedback voltage of the IC (VFB), the desired output voltage (VOUT), the additional positive dc bias voltage (VOFFSET), and the resistors of the resistive divider R1 and R2:
The recommended values for the resistive divider are for a total value of R1 plus R2 of between 100 and 500 kΩ. This keeps the bias current low enough with regard to power efficiency, but high enough to prevent excessive noise coupling into the sensitive feedback path.
This concept generally works well for generating voltages below the specified minimum voltage of a switching regulator or linear regulator. However, a few things should be considered. The additional voltage reference should be up and running before the dc-dc converter is switched on. If this auxiliary voltage is at 0 V or has a high impedance, the dc-dc converter might generate an excessively high voltage and damage the load circuit.
In the worst-case scenario, in which the switching regulator isn’t yet switched on but the auxiliary voltage has already been applied, the current IFB through the resistive divider will charge the output capacitor to voltages above the set voltage. This can happen when the load has a very high impedance. It may be necessary to install a minimum load to avoid this scenario.
The accuracy of the auxiliary voltage at the resistive divider (1 V in Fig. 2) contributes directly to the accuracy of the generated supply voltage. Thus, an especially “clean” voltage with low ripple should be used.
Furthermore, not every voltage converter is suitable for this type of operation. For example, the measuring range of the current-sense amplifier in a dc-dc converter might only provide for an operating range at higher voltages. It should also be noted that generating very low voltages with fairly high input voltages requires a low duty cycle. Therefore, it might be helpful to choose a switching-regulator IC with a short minimum on-time and operate it at a low switching frequency.
For operating a linear regulator or switching regulator with lower output voltages than intended by the IC manufacturer, an initial check using a simulation tool such as Analog Devices’ LTspice can be useful. Figure 3 shows an LTC3822-based circuit with an additional voltage source as a bias for the feedback path generating an output voltage of 200 mV. According to the datasheet, the LTC3822 is suitable for generating minimum output voltages of 0.6 V.
Figure 3. | A simulation tool such as LTspice from Analog Devices can be used for initial testing of the circuit to verify that the configuration will work with these components (in principle). |
In the circuit, the auxiliary voltage source V2 could be implemented with an LDO regulator or a voltage reference. With the “trick” described here and thorough testing of the circuit, even lower output voltages can be generated.
