Search results: 846 Output: 1-10
  1. Stephen Woodward
    Current mirrors are a commonly useful circuit function, and sometimes high precision is essential. The challenge of getting current mirrors to be precise has created a long list of tricks and techniques. The list includes matched transistors, ...
    Nov 27, 2025
  2. Christopher Paul
    Audio Oscillators Texas Instruments TLVH431 TLVH432 TLE2027
    This project made me feel a kind of kinship with Diogenes, although I was searching for the item described in the title rather than for an honest man. Figure 1. “Diogenes Looking for an Honest Man,” a painting attributed to Johann ...
    Nov 24, 2025
  1. T.K. Hareendran
    The Norton amplifier topology brings back the essence of analog design by using clever circuit techniques to deliver strong performance with minimal components. It is not about a brand name it’s about a timeless analog philosophy that ...
    Nov 20, 2025
  2. Frederik Dostal
    Supply Analog Devices LT4422 LT4423
    Abstract Robust systems often allow multiple power sources. When different power sources are used to power a device, switches need to be implemented to separate the power supplies from each other to avoid damage. This can be accomplished with ...
    Nov 18, 2025
  3. T.K. Hareendran
    Electronic components Automation Beginners Vishay TCST1103/1202/1300 TCRT5000
    A homing sensor is a device used in certain machines to detect a fixed reference point, allowing the machine to determine its exact starting position. When powered on, the machine moves until it triggers the sensor, so it can accurately track ...
    Nov 13, 2025
  4. Stephen Woodward
    It’s just a fact of life. A BJT wired in common emitter, even after compensating for the effects of device and temperature variations, still isn’t a perfect current source. One of the flaws in the ointment is the Early effect of ...
    Nov 7, 2025
  5. Damian Bonicatto Phoenix Bonicatto
    For the past couple of years, I’ve been using AI to assist in the design of my hardware and firmware projects. The experience has generally been good, even though the outcome isn’t always useful. So, I’m presenting a short summary ...
    Oct 30, 2025
  6. John Dunn
    High school trigonometry combined with four-quadrant multipliers can be exploited to yield sinusoidal frequency doublers. Nothing non-linear is involved, which means no possibly strident filtering requirements. Starting with some sinusoidal signal ...
    Oct 11, 2025
  7. T.K. Hareendran
    Hybrid relays are changing the way we think about switching inside electronic circuits. By combining the fast response of solid-state components with the reliability of mechanical contacts, these devices offer the best of both worlds. Whether you ...
    Oct 6, 2025
  8. Damian Bonicatto Phoenix Bonicatto
    Increasing ADC resolution Many electronic designs contain an ADC, or more than one, to read various signals and voltages. Often, these ADCs are included as part of the microcontroller (MCU) being used. This means, once you pick your MCU, you have ...
    Sep 30, 2025
