The circuit in Figure 1 computes the derivative of an input signal as the integral of the input signal minus the signal itself.
| Figure 1. | This circuit produces less noise than the classic inverting differentiator. |
The response of the circuit is
where REQ is the parallel equivalent resistance of R1 and R2 plus the resistance of R3, or
This response is identical to that of the classic inverting differentiator, in which the response is
for input frequencies lower than
If R3 is much greater than the parallel combination of R1 and R2, then REQ ≈ R3. On the other hand, if R3 is set at 0 Ω, the bias currents of the op amp balance to minimize voltage offsets, and
A major problem with the classic inverting differentiator is high noise. By its nature, a differentiator must exhibit increasing gain with frequency, and this increasing gain amplifies the inherent amplifier noise. An equivalent input-noise voltage, VN in the classic inverting differentiator, produces output noise of magnitude RCsVN. In the case of the differentiator in Figure 1, the equivalent input noise produces an output magnitude of only
