El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
A monolithic switching regulator …
A monolithic switching regulator (left) and a solution with a controller IC (right), each with the geometrical arrangement of the hot loop
Frederik Dostal
Monolithic Switching Regulator—When Everything Is on a Chip
Figure 2
17 Kb
Figure 1. Monolithic buck converter (left); controller solution with external switches (right)
Figure 2. A monolithic switching regulator (left) and a solution with a controller IC (right), each with the geometrical arrangement of the hot loop
