Four 2.5 V references, IC1 through IC4, produce 10 V. Resistors R1 and R2 form a voltage divider that reduces the 10 V output to 2.5 V and lowers the output-noise voltage by half. Buffer amplifier IC5
AuthorsAlfredo Saab, Steve Logan
Main DocumentArticle «Reduce Voltage-Reference Output Noise by Half»
DescriptionFigure 1
File Format / SizePDF / 20 Kb
Four 2.5 V references, IC sub 1 /sub  through IC sub 4 /sub , produce 10 V Resistors R sub 1 /sub  and R sub 2 /sub  form a voltage divider that reduces the 10 V output to 2.5 V and lowers the output-noise voltage by half Buffer amplifier IC sub 5 /sub
