With greater light intensity on the LED, the decay time (TD), during which the voltage on P1 discharges, is shorter (a). The voltage on P2 goes high if TD exceeds TDCR (b). These are experimental results using a 5-mm, high
Figure 3. With greater light intensity on the LED, the decay time (TD), during which the voltage on P1 discharges, is shorter (a). The voltage on P2 goes high if TD exceeds TDCR (b). These are experimental results using a 5-mm, high
