El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
A typical feedback loop …
A typical feedback loop for a voltage regulator can be adapted to create a power regulator for a load with varying impedance
Dave Sackett
Supply Constant Power Level To A Varying Load Impedance
Figure 1
18 Kb
Figure 1. A typical feedback loop for a voltage regulator can be adapted to create a power regulator for a load with varying impedance
Figure 2. The feedback loop in the power regulator ensures that the power to the varying load remains relatively constant
Figure 3. The power output for the circuit in Figure 2 remains well regulated for a wide range of loads and for various values of VPOWER_SET, which range from 0.0021 (bottom) to 0.0300 V (top).
