El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
An auxiliary winding supplies …
An auxiliary winding supplies power to the supply's PWM controller
Michael O'loughlin
Shunt regulator eases power-supply-start-up woes
Figure 2
44 Kb
Figure 1. An uncomplicated block diagram (a) conceals the TL431's internal complexity, but you need only three external resistors to use the TL431 in a basic shunt-regulator circuit (b)
Figure 2. An auxiliary winding supplies power to the supply's PWM controller
Figure 3. In this improved design, pulse-width-controller IC
1
derives its power from R
T
for start-up, auxiliary winding W
AUX
for normal operation, and shunt-regulator circuit IC
2
and Q
1
for low-load operation
Standard precision GNSS module. Datasheet MIA-M10Q
