Search results: 868 Output: 1-10
  1. Stephen Woodward
    After more than fifty years of continuous production in bipolar and fully half that in CMOS, there’s really neither room nor reason to question the value and versatility of the venerable 555 analog timer. But if it has any significant ...
    Mar 25, 2026
  2. Frederik Dostal
    Abstract This power management tip introduces the two different circuits for a positive-to-negative voltage conversion and for a negative-to-positive voltage conversion. It explains how a step-down (buck) regulator circuit may easily be modified to ...
    Mar 24, 2026
  1. Joribo
    Supply ON Semiconductor LM2904 LM7805
    We regenerate these type of alkaline batteries [1] here: (not normal rechargable ones ) The schematic The schematic is rather trivial (Fig. 1). A voltage regulator brings down a supply voltage (which might be from a car battery) to 5 V. An ...
    Mar 23, 2026
  2. Thomas Kugelstadt
    Interfaces Texas Instruments SN65HVD23 SN65HVD24
    Modern high-speed RS-485 data links are pushing the envelope to the absolute breaking point with regards to data rate versus cable length. Applications include position encoders, traffic monitoring, seismic networks, and GPS transceivers. Data ...
    Mar 13, 2026
  3. Uwe Schüler
    In this Design Idea (DI), the classic Schmitt-trigger-based RC oscillator is “hacked” and analyzed using the simulation software QSPICE ( Ref. 1 ). You might reasonably ask why one would do this, given that countless such circuits ...
    Mar 13, 2026
  4. Herminio Martinez
    Applications such as audio equalizers require bandpass filters with a constant maximum gain that's independent of the filter's quality factor, Q. However, all of the well-known filter architectures Sallen-Key, multiple-feedback, ...
    Mar 6, 2026
  5. Bill Schweber
    We’re all familiar with thermally activated fuses, where the conducting element self-heats due to current flow, melts at a defined current value, and breaks the flow path. They are simple in concept (although they have their own subtleties, ...
    Mar 5, 2026
  6. Bill Schweber
    I have always been intrigued by the many ways scientists and engineers have devised to sense basic physical parameters such as temperature, pressure, voltage, current, and electric fields, to cite just a few. In some cases, the challenge is the ...
    Mar 4, 2026
  7. John Dunn
    Any semiconductor has limits on how much voltage, how much current, and for how much time combinations of voltage and current can be supported in normal usage. Sometimes that information is provided as part of the device’s datasheet, and ...
    Feb 28, 2026
  8. Simon Bramble
    Abstract This article describes a circuit that facilitates the measurement of currents from amps to hundreds of amps with a high degree of precision. Introduction There are many applications that require the measurement of current. Many digital ...
    Feb 24, 2026
