Search results: 903 Output: 1-10
  1. Stephen Woodward
    This silly simple circuit cancels out potentially serious digital potentiometer zero- and full-scale errors. Everybody (well, most everybody) knows that digipots tend to be more accurate when used as variable voltage dividers (i.e., in ...
    Oct 15, 2026
  2. Raju Baddi
    Supply Fujitsu RAL-D5WN-K
    You can install the bench-top accessory in Figure 1 between a variable-voltage bench power supply and a breadboard or UUT (unit under test) to protect against accidental over­voltage and reverse polarity. It draws its power from the supply and ...
    Sep 30, 2026
  1. Jason Lomberg
    A new report confirms what most of us already knew that data center energy demand is rapidly outpacing supply. And for those who’ve heard of the smart grid so 99% of us) the concurrent issue is no less surprising delivering the electricity ...
    Sep 29, 2026
  2. Robert Heider
    How to design a simpler filter (or filter-like circuit) with a varying time constant dependent on what kind of waveform is fed to it. Discussions with some former coworkers have focused on how to design a filter or circuit with filter-like ...
    Sep 17, 2026
  3. Jason Lomberg
    As AI data centers sprout up across the globe, we’ve begun grappling with AI’s not-so-hidden secret it has a voracious, unquenchable appetite for power. Some cities have even passed moratoriums on new AI data centers because of their ...
    Sep 17, 2026
  4. Michael Wyatt
    Butterworth response circuits come in both low- and high-pass versions, as well as ideal, Sallen-Key, emitter follower and DC accurate variants. Many decades ago, I published a Design Idea about using equal value resistors and capacitors to ...
    Sep 10, 2026
  5. T.K. Hareendran
    Gray codes, also known as reflected binary codes, offer a clever way to minimize errors when digital signals transition between states. By ensuring that only one bit changes at a time, they simplify hardware design and reduce ambiguity in ...
    Sep 9, 2026
  6. John Dunn
    The frequency response of a Butterworth filter is not supposed to have any peaking. SPICE claims the contrary. I came across an online datasheet for some op-amps where I found two schematics that intrigued me. Screen-shotting them together resulted ...
    Aug 24, 2026
  7. Frederik Dostal
    Abstract This article explains why Bode plots are used to showcase the transfer function of a power supply loop. While there are load transient tests in the time domain, the results do not show other important information that a Bode plot does. ...
    Aug 13, 2026
  8. Zeev Collin
    Power line communication (PLC) has been around for decades. It’s a foundational technology for smart grids and industrial networks. Yet, despite widespread deployments, it’s still widely misunderstood. As energy infrastructure expands ...
    Aug 12, 2026
