El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Power supply undervoltage lockout …
Power supply undervoltage lockout using a resistive divider, comparator, and power switch
Pinkesh Sachdev
Adding Hysteresis for Smooth Undervoltage and Overvoltage Lockout
Figure 1
16 Kb
Figure 1. Power supply undervoltage lockout using a resistive divider, comparator, and power switch
Figure 2. Undervoltage and overvoltage lockout using a single resistive divider
Figure 3. Adding undervoltage lockout threshold hysteresis with a resistor from the divider tap to the power switch output
Figure 4. Adding undervoltage or overvoltage lockout threshold hysteresis with a switched (a) shunt resistor or current and (b) a series resistor
