El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Primary-side clamp circuit uses …
Primary-side clamp circuit uses a general-purpose comparator and a couple of small-signal transistors
Ben Lough
AC/DC power-supply startup considerations for PMDC motor loads
Figure 4
13 Kb
Figure 1. Simplified model of a DC motor illustrates the PMDC characteristics
Figure 2. The AC/DC supply block diagram highlights constant-current and constant-voltage regulation loops
Figure 3. Startup with a duty-cycle clamp enables a small initial voltage
Figure 4. Primary-side clamp circuit uses a general-purpose comparator and a couple of small-signal transistors
Figure 5. Clamp circuit states are shown vs. output voltage rise
