El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
This fully differential circuit …
This fully differential circuit compensates for voltage drop and phase shift in transmission lines
Ron Shakery
Correct voltage drop and phase shift in transmission lines
Figure 1
14 Kb
Figure 1. This fully differential circuit compensates for voltage drop and phase shift in transmission lines
Figure 2. This circuit represents a simulated transmission line inserted between points A and B of the circuit in Figure 1
Figure 3. The phase-shift curves at Node B before the transmission line and at Node C after the transmission line show the effect of the feedback path in correcting the phase shift at the end of the transmission line
