El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
An inverting buck-boost topology …
An inverting buck-boost topology for generating a negative voltage with a step-down (buck) switching regulator
Frederik Dostal
Generating negative voltages - why you need level shifting in buck-boost circuits
Figure 1
13 Kb
Figure 1. An inverting buck-boost topology for generating a negative voltage with a step-down (buck) switching regulator
Figure 2. External level shifter for supplying the switching regulator IC with an external clock for synchronization
Figure 3. A MAX17579 designed as an inverting buck-boost regulator and with level shifting already integrated
