El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
The controlling output in …
The controlling output in this circuit uses two switches
Jean-Bernard Guiot
Active multiplexing saves inputs
Figure 2
12 Kb
Figure 1. The controlling output in this circuit uses two switches
Figure 2. The controlling output in this circuit uses two switches
Figure 3. You can use this circuit to reduce the number of inputs coding the switches
