Changing the value of RB adjusts the SEPIC voltage's setpoint to accommodate different solar panels' voltages. You can adjust a resistor divider comprising RT and RB to match the SEPIC's reference voltage, typically 1.34 V
AuthorsRamesh Khanna, Frank Edrada
Main DocumentArticle «Solar panel powers two-stage lead-acid battery charger»
DescriptionFigure 7
File Format / SizePDF / 10 Kb
Changing the value of R sub B /sub  adjusts the SEPIC voltage's setpoint to accommodate different solar panels' voltages You can adjust a resistor divider comprising R sub T /sub  and R sub B /sub  to match the SEPIC's reference voltage, typically 1.34 V
