Circuits & Schematics
Search results: 2,111 Output: 1-10
  1. Tim Davis
    Dual precision comparators are needed in many designs, such as for industrial and instrumentation applications, to generate accurate pulse-width modulated (PWM) waveforms with very high ( 99%) and very low ( 1%) duty-cycle percentages. This design ...
    Apr 4, 2025
  2. Vijay Deshpande
    This modular resistor load bank uses a unique topology to reduce the number of switches and resistors while providing the maximum number of steps. An array or bank of load resistors is often required for testing power products, characterization of ...
    Apr 1, 2025
  1. Rod Elliott
    Introduction In general, muting and/or signal switching is done by relays, FETs or CMOS analogue switch ICs. All have limitations, but a little known technique that really doesn't look like it could ever work is to use bipolar transistors. The ...
    Apr 1, 2025
  2. Stephen Woodward
    Circuits Measurement Texas Instruments CD74AC14 CD74AC74 CD74AC161 SN74LVC1G14 TLV9161
    Famous analog designer and author Jim Williams published an awesome design in 1986 for a 100-MHz voltage to frequency converter ( Ref. 1 ). He named this high-climber (picture it on the roof of the Empire State building swatting biplanes out of the ...
    Mar 25, 2025
  3. Stephen Woodward
    Frequent design idea (DI) contributor Nick Cornford recently published a synergistic pair of DIs “A pitch-linear VCO, part 1: Getting it going” ( Ref. 1 ) and “A pitch-linear VCO, part 2: taking it further” ( Ref. 2 ). The ...
    Mar 24, 2025
  4. Nick Cornford
    In Part 1, we saw how to make an oscillator whose pitch, as opposed to frequency, can be made proportional to a control voltage. In this second part, we’ll look at some alternative ways of arranging things for other possible applications. To ...
    Mar 14, 2025
  5. Madhu Siddalingaiah
    If you've ever designed an RF oscillator, you've probably encountered squegging. Sometimes called motor boating, squegging causes oscillators to start and stop at frequencies much lower than the frequency of interest. Viewed on an ...
    Mar 11, 2025
  6. Christopher Paul
    The recent Design Idea “Getting an audio signal with a THD 0.0002% made easy” [ 1 ] discloses a low THD sine generator which led me to dust off a design that I had published in AudioXpress magazine [ 2 ] (see Figure 1). Figure 1. A ...
    Mar 7, 2025
  7. Stephen Woodward
    It’s remarkable how many switching regulator chips use the same basic two-resistor network for output voltage programming. Figure 1 illustrates this feature in a typical (buck type) regulator. See R 1 and R 2 where: Quantitatively, the V ...
    Mar 7, 2025
  8. Israel Schneiderman
    Circuits Digital Texas Instruments LM393 SN74HC74 SN74HC86
    Traditionally, the reception quality of a digital receiver is expressed in terms of BER (bit-error rate). This figure is the proportion of received bit errors in a given period. Typically, you measure the BER in the lab by applying an RF signal, ...
    Mar 4, 2025
