El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
An inverting buck-boost converter
Anthony Serquiña, Jhun Rennel Sanchez
How to create a dual-output voltage rail with source and sink functionality for ATE applications
Figure 2
7 Kb
Figure 1. A buck converter
Figure 2. An inverting buck-boost converter
Figure 3. Converting a buck converter to an inverting buck-boost configuration
Figure 4. A buck IC used in an inverting buck-boost topology
Figure 5. (a) Current flow during on-time, (b) current flow during off-time, (c) the current through the top/control MOSFET (I
CTR
), (d) the current through the bot/sync MOSFET (I
SYNC
), and (e) inductor voltage
Figure 6. (a) Current flow during on-time, (b) current flow during off-time, (c) current through the top/control MOSFET (I
CTR
), and (d) current through the bot/sync MOSFET(I
SYNC
Figure 8. A block diagram for the setup
