El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
a) Programming the DAC's …
a) Programming the DAC's output voltage changes R
EQ
, which can balance a bridge circuit. b) Equivalent circuit
Alexander Bell
Program resistance in a bridge circuit
Figure 2
10 Kb
Figure 1. By measuring V
BRIDGE
and adjusting R
EQ
, you can balance a bridge circuit and calculate R
T
Figure 2. a) Programming the DAC's output voltage changes R
EQ
Figure 3. This schematic of a circuit uses a comparator across the bridge
